MECHANICAL SIMS ???
VIPER D.N.A
Just dropped my truck off to get my midpipes from justin put on. The local exhaust shop wouldnt touch it, so its at an off road place. They are not quit grasping the concept of the mechanical sims, so the dummy lights dont turn on. I'm no expert on this so my question in whats the best way to tell them what needs to be done? Or is it something I can fix later if the lights still on. gonna call them in a few. Thanks in advance
if you have an RC i would just get a mopar performance pcm. the mopar performance pcm shuts the rear o2 off so they wont send a signal. there cheep and you gain some performance. if you have an QC then get the sims.
Talk to Justin..he will fix you up and solve the problem at a low low cost.
You should have recieved some "02 sims" which bascially look like a spacer for the rear 02 sensors. Install them into the rear sensor holes in the mids, then the sensors into the sims and your set.
Justin
Justin
And they are dummy proof. You cant plug the back ones into the front holes..........the connections are different. I know this because my installer tried and called me up to tell me my sims werent connecting..... then he couldnt even hook it up back to stock!!!!!:dontknow: I figured it out that he had em all backwards!!!
But getting the mopar pcm or other will alleviate the cel problem and give some more powah!!!:rock:
patrick
