Meth Injection Inline Filter..
TNVIPER
God's Chosen Land....East TN
I was thinking that a inline filter would be a good idea for a meth injection system since the nozzles have very fine holes................what would work?....inline fuel filter?......what is meth proof?...ideas???:dontknow:
Larry, just buy boost juice. It will not create any build ups or deposits like regular windshield washer fluid will. I was actually suprised to see how much mineral deposits had built up on the nozzle when we did the disassembly. The meth was probably barely working.
George I had actually been using Boost Juice since installing the meth inject......just a few days ago I bought Devil's Brew and I swear the truck runs stronger.....IAT temp drops faster and 10 degrees lower than the BJ.......regardless I was still thinking any small debris falling in the tank would eventially clog the injector....:dontknow:
TNVIPER said:
Here you go..
http://www.alcohol-injection.com/premixed-methanol-44/devilsown-brew-125.html
But if you can find methanol local you can mix your own. Only place that sells it around here is the drag strip (Bristol) ($4 a gallon)..and only when open....I ordered it online because I just could not get time to run up to the track..
Thanks for the link,but the red writting on the bottom,takes me OUT!!! That sucks.:mad: ,I can get water/meth mix,it was just that if it works better then the others,I'm totally interested:rock: .
Didnt think about that out of the country no-no..:(.......hate that for you. If you can get Meth you should be able to mix the same. The Devils Brew is just 49% meth and 51% water....I dont think they add anything though my truck is responding like it never did with the Boost Juice which was supposed to be the same mix...maybe I got a bad mix with the Boost Juice.:dontknow:
I'm running a filter on mine. Ordered one with the rest of my FJO setup.
...an ounce of prevention.
