QuadFor4
I have an 05 quadcab with 63000 miles which has a random misfire on the #4 cylinder. It happens at random speeds and RPMs. The CEL keeps coming on, otherwise I would not know its happening. The truck seems to run flawlessly... No backfires, burps, hiccups or what ever else you may use to discribe a misfire.
I have put a new plug wire to that cylinder, switched plugs and fuel injectors between cylinders, ran seafoam threw the top end, fuel injector cleaner threw a tank of gas. Now here is another curve ball...if the truck sits for several hours or over night, it will not throw the trouble code until after I drive somewhere and shut it off. When I start it back up and start to drive after a few minutes to a couple hours later it will then throw the code.
The truck has venom coils and JTS wires (40,000 on them), champion plugs have 12,000 on them, tuned by Justin, headers and back are BB exhaust, JTS throttle body.
Any help or ideas will be appreciated.
