mosrt10
I get 5w-30 at mine for that price.
HOT RAM said:I think 04s use 10w30 and 05s use 10w40.More importantly is the rating .Use the SL .It is better than the newer SM,which is designed with catalytic converter longevity in mind rather than your engine.I am currently using the Mobil 1 Turbo Diesel truck oil.The newer Mobil 1 is SM rated and in this case newer is NOT better !
Prof said:Paid $19.97 for five quart containers of 10w30 syn at Walmart today...sign said reduced price...bought five jugs!
They had 10w40 and 15w50 at the same price...
I thought the price was good...maybe not?
Actually 04's are 10-30 ......... check your 710 capProf said:'04's are 10w40 really shouldn't make too much difference...
If you are warranty minded at all, the manual does say every 3000 miles or 3 months which ever comes first :burnout:chase said:Prof,
Not to drag this on but yiou change your oil every 3k? I figured with synthetic I could go 5k or poss even 7.5k?
The oil only thins out from heat. Let your truck cool down and check your oil. You will see its back to normal. Annu get yourself some tools and start doing this stuff yourself. $175 is way to much to spend on a oil change.Annu Kumar said:3000 K is good. Ted may Showed me my oil after 2500 miles and it started to thin out:dontknow: Like patrick said check the condition of your oil periodiacally and change according to how you drive. Heat is Bad
Wifey said:If you are warranty minded at all, the manual does say every 3000 miles or 3 months which ever comes first :burnout:
Prof said:Buy 10 quarts...you will only need about 6 or 7 but since it is the first time, you will spill at least 2 or 3 quarts. Until you learn it is a messy job. You can get the Mobil 1 Syn ATF anywhere they sell Mobil 1 Syn oil.
When you drain your transmission you will see what comes out...it looks like sewer sludge, grayish green...gear oil. I trust the manufacturer of the transmission more than the manufacturer of the truck.
AWDisuzu said:who spills 2 or 3 quarts when doing an oil change? damn dude get a funnel!
