SRTHOR
I'm lobbing up a home run for you guys, I haven't been able to find out differences between the 04, 05, and 06 MY trucks. I saw snippets about different gears. Like 4.10 in 04 and 4.56 in 05/06. True? If so did they use the 4.10 to achieve the top speed record or is it the same regardless of rear end. Did they change first gear or anything with the transmissions when switching rear end gearing?
I don't think I've ever seen an 04 with a stock tonneau cover, did 04 come with tonneau covers or not? All 05, 06 did? Does the tonneau cover help with down force or mpg or hurt (based on the tail gate up/down thread). I know the wing helps, how is the wing affected by having or not having the tonneau cover?
Did the 06 only come in the gray interior? Looks like the 04/05 have the same interior?
Any motor or ECU adjustments made after 04?
Any other changes to note or any of the special packages add anything besides badging and paint colors?
