Muffler change
walenator
Gainesville, Ga.
Is it important to disconnect your battery for 15 min to reset the PCM when changing to Flowmaster? If so can I just unplug the connectors to the PCM. I didn't want too have to reload the Nav. :p
I am not sure if it is "needed" although when I have done any perfomance mod I always disconect the battery first.
I would disconnect it just in case. Let us know what you think of the flowmasters. Someone just had an issue last week where the flowmasters made them lose power.
The engine computer will adapt to the difference over time - disconnecting the battery will reset the adaptations to zero, possibly allowing the computer to adapt a little sooner. Either way will work out in the long run...
Let us know how you like the Flow
