metalme2
Hey all,
I've seen several old and new posts about this topic so I'm hoping to consolidate the possible reasons...
My 2006 QC shifts fine (albeit sharply due to shift kit) at slow acceleration. When I bought it two weeks ago, I replaced the TPS sensor.. and had the trans serviced as well as replaced the Governor Pressure Solenoid with a Borg Warner.
I'm not sure if I did the TPS properly.. I just removed the old, installed the new one, started the truck, ran through some wot events to theoretically calibrate it.. And that was it..
It was going ok for a bit, then started to get progressively worse... Now not just wot but close to it... And seems to really be when the trans shifts down twice rather than once.
Each time there have been cars around so I haven't stared at the tach to see if I'm hitting the limiter.. But it feels like a combo between the trans not shifting in time thereby allowing the engine rpm to hit the limiter... Severely annoying as I go to pass someone, press too hard on the gas...and the truck bucks like a pissed mule...
So...
TPS
Replace gov press solenoid
Adjust bands
Do I now clean the IAC?
adjust the throttle valve cable? (saw that somewhere on the forum)
Seems like something is out of adjustment... Not major..
Please any thoughts would be appreciated.
Note: I bought the truck used from a used car dealership. They had no info to give me so thanks to ViperJeff... I found out previous owner installed a Volant CAI, 180 thermostat, shift kit.. I wonder if its ever had a custom tune but have no idea.
Thanks all
So...
TPS
Adjust bands
Thanks all
