MY NEW GRILLE INSERTS
SANCHOBA
TEXAS A&M DAD
INGLESIDE,TX.
finally got around to doing some work on the truck, these are the brushed aluminum speed grilles painted semi-flat black. truck has more of an attitude,if thats possible! LOL:rofl: . its a real close match to the lower inserts:rock: also took the RAM badges off!:hahaha:
Very Nice.
Attitude is what you got.....Intimidating is what it is.....:D
well i don't know how to paste the link for that paticular item, try typing in this part # 950-77507
installing was somewhat of a PITA,instructions state to install from outside,but that won't work,clips that are supplied with these inserts are crap they will gouge into the plastic.had to cut the edge of the inserts and bend to make tabs which i screwed to areas where the original was mounted. some advice on painting:
1.clean with detergent well to remove any oils from manufacturing
2. etch the aluminum with chemprime or ospho
3.prime with a quality aluminum spray paint,then finish with color of your choice!
wasn't all that bad!;)
Looks good mang I had the inserts on my 02' Ram and I agree the install on those things is a bitch and a half plus I wasn't pleased with those clips or how they held up at all!!
Sanchoba as allways man you set the standards! That thing is awesome!
you need a poster about 4'x4' to hang on the garage of that ride!
