Need 48lbs injectors
blackviper
Miami, FL
Looking for set of 48lbs Siemens long injectors. I need them only for break-in.
Thanks Larry. Unfortunately, those no longer fit the modified intake. The thickest part of the injector's body rubs up against the 3/4 inch spacer plate. So it has to be a Siemens style injector.
I have a set of 69 pounders to be used after break-in but I want to do the initial start up on my original tune.
George I recently put the 69s in mine. Torrie (Unleashed Tuning) did a temporary tune based on the 93 oct tune he had done before. I am running that tune now w/o issue until we do the dyno tuning Aug 4.
Sean should be able to do the same providing you were using his tune. This would get you running until you do a dyno session.
Sean has already sent me a file but I'm still looking into the possibility of using my current tune. I'm just kind of nervous firing it up for the first time on a generic tune. I don't want to wash anything out.
