TNVIPER said:just a FYI....The injectors for the Roe are "long style"....the OEM injectors are the "short style"....make sure you know what you are buying..
Running these also and yes they will be rated higher with those fuel pumps.Ramchargerguy said:The ones I bought are the 69#/hr at our fuel pressure bought them from racetronix. Don't know if this we will enough flow for you.
http://www.racetronix.biz/itemdesc.asp?ic=FI114961&eq=FI114961%2D10&Tp=
blown04 said:
Ramchargerguy said:The 107961 are the long style
The 107962 are the short style
Both are on the site.
Ramchargerguy said:You have to do look through the "63 #" they have both on the site
Short style: http://www.racetronix.biz/itemdesc.asp?ic=FI114962&eq=&Tp=
Long style: http://www.racetronix.biz/itemdesc.asp?ic=FI114961&eq=&Tp=
I just use the last 3 digits to search 961, 962
TNVIPER said:I dont see a part # 107962??.....only FI114962...:dontknow:
blown04 said:It's under Retail P/N: 107962
TNVIPER said:I know...I just wondered why he didnt post the item #...
Ramchargerguy said:I did it this way cause my suppliers doesnt deal with Seimens injectors so we used the retail # in there system for an interchange and I found out the accel injectors are $20 more my cost and the msd ones are almost double that. And both don't come as flow matched sets. This was before I found them on the racetronix site.
TNVIPER said:I just wondered since a search with the 107962 # would not turn up anything on that site....good find....and yep, they are the same as on Roe's site...I had a set...
Yellow venom said:What are you running now Larry?:dontknow:
