kickinassrt-10
So I decided I want eyebrows on my lights and figured the best way is to paint them for an 05 since they aren't made. I plan on taking the light off and scuffing the part I'm painting with a scotch bright or similar so the paint will adhere. The lens is clear so I figure I should either use several coats of the silver or use a darker color as the base coat and then painting the silver over that. What would you suggest? Also I was told by dodge that ws2 and ps2 are the same paint...bright metallic silver?
Thanks
Thanks
