Need electrical diagram
Floor
Belgium Antwerp
Does someone have a the electrical diagram of the 2005 QC models?
I need to add a rear fog light and towing socket. In this towing socket
the sign lamps and rear/stop lights must be separated for local requirements.
A electrical shematic would help doing these changes.
Thks wizards !:D
if by sign lamp you mean turn signal, I believe that they are using the same circuit as the brake light in these trucks. you may have to run a new wire.
here is the manual.
http://www.kuriger.net/srt10.pdf
Thks wizards !:D
Borden3srt said:
send me your email and i will try to get all of them out.
the rear turn signal are on a seperate circuit so you should be able to tap into those seperately.
I also think the rear signal light and rear light are one bulb so I was thinking
to tap from the front signal light and route them to the socket near the tow hitch.
Anyway, my email is [email protected]
Looking foreward to yr reply :knuddel: :D
(I might not be able to check it right now cause my LAN port of the other PC is broken. I'm trying to make copy the settings on the old laptop I'm using now):hmmmm2:
