need help asap
''500hp''
i finally got somone to delete the two rear cats on my qc but bye deleteing the two rear will that cause a light to pop up? and will i have to have my pcm reflashed i have a b&g tune does it affect the tune at all im doing this in about an hour any input would be great
i took all four off and ziptie the sensors to the frame and no problems so far. btw its been a bout a year
you should get no light at all ,,should not affect tune at all either !
you might want to reset the comp. by disconnecting the negative battery cable for 15 minutes or so. you want to do this whenever an engine mod is done.
my biggest concern is it afecting the tune so it wont thats great thanks guys :rock:
ok dont know where else to post this. has anyone else had sub woofer that just quit working? my hubby's did for no apperent reason! truck is an 04
Welcome moonmullins, Yes there have been several.:(
making sure i get this right cause i need to have fixed or replaced. hubby is blaming me for my loud music being its downfall. so im not the only one. is there a particular reason?
Ooopps, Cats out of the bag. Have him get on, And maybe we can help.
here your out of the dog house er.....cat house!
TSB
Date: January 12, 2006
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. DO NOT ORDER PARTS OR
PERFORM ANY ACTIONS RELATED TO THIS BULLETIN UNTIL JANUARY 30, 2005.
Models: 2004 - 2005 (DR) Ram Truck SRT10
Overview:
This bulletin involves replacing the 2 channel Audio Amplifier (AMP) and 8 channel AMP.
Symptom/Condition:
Crackle, pop, and static sounds heard from subwoofer speaker (most noticeable at
key-on). Also reduced subwoofer output is possible
TSB
Overview:
Symptom/Condition:
Good save bro.:rock:
not worth repairing...cheapest route :ask one of these fellas if they have one laying around,alot of the guys have upgraded. start a thread in the buy/sell section. haven't had any problems with mine...of course the captain and tennille just doesn't sound that great cranked all the way up!
ok being that i am a woman. which is actually the problem? speaker or amp? and was that a stupid question?
most likely the amp under the center seat...but without being able to check a couple of things i can't be 100% sure.:dontknow:
well hubby sorta thought the same thing. i just wanted to get second opinions before he touched it. another question... is there a fuse for the amp? and what brand do u recomend that will work better and fit in that small space?
No stupid questions here.
Probably the speaker.
You can tell your husband that it is often caused by not driving it hard enough from time to time to stretch out the fiber cone. It really needs stretching every time you use it.;) ;)
