Tomorrow I'll be pulling out the radio. What needs to come out in order to do so? Any tips will be greatly appreciated. Thanks.
The top of the center console is held on by clips. It just pulls straight up.
Then the lower section of the console is held on by 3 bolts. You need to remove this. Then there is a collar around the base of the dash, I believe it is 2 pieces, you need to remove them to get at the 2 screws that are facing upwards. Once those 2 screws are removed, the dash bezel will pop off. pull straight out (towards the back seat) The wood grain and the gray/silver piece are all one piece, unplug the wiring to the power outlet, cig lighter and A/C controls, and you are done.
I would highly recommend leaving the 2 screws facing upwards out when you put it back together. This way if you need to get the bezel off, it will just pop off, no need to remove the console again.
blackviper said:Thanks for your help. I'll go at it first thing tomorrow morning.
