Need PCM Pinout
sinus19
ASD Fuse blew out again... Need pin out for the middle (white) connector on the PCM to trouble shoot.
What year and cab configuration is the truck?
POWERTRAIN CONTROL MODULE C2 (SRT) - WHITE 32 WAY CAV CIRCUIT FUNCTION
1 - -
2 K26 18BR/YL INJECTOR CONTROL NO. 7
3 K115 18BR INJECTOR CONTROL NO. 9
4 K11 18BR/YL INJECTOR CONTROL NO. 1
5 K13 18BR/LB INJECTOR CONTROL NO. 3
6 K38 18BR/OR INJECTOR CONTROL NO. 5
7 - -
8 - -
9 - -
10 K20 18BR/GY GEN FIELD CONTROL
11 - -
12 K58 18BR/VT INJECTOR CONTROL NO. 6
13 K28 18BR/LB INJECTOR CONTROL NO. 8
14 K116 18BR/WT INJECTOR CONTROL NO. 10
15 K12 18BR/DB INJECTOR CONTROL NO. 2
16 K14 18BR/TN INJECTOR CONTROL NO. 4
17 C240 18LB/TN HYDRAULIC COOLING CONTROL FEED
18 - -
19 C918 18BK/LB A/C PRESSURE SENSOR GROUND
20 - -
21 K333 18DB/LB SOLENOID REVERSE LOCKOUT FEED
22 - -
23 G6 18VT/GY OIL PRESSURE SIGNAL
24 - -
25 - -
26 - -
27 B22 18DG/YL VEHICLE SPEED SIGNAL NO. 1
28 - -
29 - -
30 - -
31 F856 18YL/PK 5 VOLT SUPPLY
32 - -
This is QC but just subtract the automatic tranny features and it's the same :)
awesome, Thanks! Found 3 loose wires. tighten them up and so far so good.
