Ok, here goes my detailing advice...take it with a grain of salt...
Two buckets.... first...
Rims and Rubber.... spray them down... Weslkey's Bleach White on the rubber...simple green on the metal... Dawn soap concentration/ water, and a good brush for the rubber, wheel well liners, and wash mit for the rim's ( I do these first.) Dump all the H2O after, and the wash mit goes in the washer.
Rinse entire vehicle from top to bottom.... Wash with Dawn if your stripping her down for clay. I begin washing from top to the top of the cladding, and do not do the tailgate, or rear bumber. Rinse... then hit the cladding, and the rear of the vehicle. Rinse... Dump all soap from bucket and clean.
Then I get outy the Clay Bar
In the clean bucket mix a car soap/water solution (bit heavier on the soap... get another clean microfiber wash mit......clean wash mit, or spray bottle...then begin claying.. following the same order as washing. (Note: if at any time you drop your clay on the ground... pitch it, and get a new piece). I do sections at a time, and after claying an area rinse, then brief wash with the mit, then move on.
Dry when complete.
Then I get out the porter cable... and use a product called Optium Polish...
http://www.optimumcarcare.com/optimumpolish.html
....it removes 1500 scratches and lighter @ 1000 - 1400 rpm with a Wool Buffing Pad, or 2000 and lighter scratches with a light cutting foam pad at the same rpm as previously stated. Same order as washing...top to bottom...front to back.
Remove after haze... then Get out your wax of choice (I use McGuires NXT) and apply with new finishing pad on the Porter Cable...same order as washing....remove.:star:
Before I remove the NXT, I use the ICE on all plastic...and remove all waxes with microfiber towels. This reduced the likelyhood of the ICS streaking the paint finish, as it's on "over" the NXT. I also dress the tires at this time in case of overspray... again...if I get it on the paint...it is still on top of the NXT...and when removing the wax...does not streak at all.
Good luck... hope it helps.
