Rickspeed
Ok so I'm really going nuts, before I pull the blower off and swap out the coil, is there a way to test the voltage through the wire going to the plug. This is where I am at. Pulled plug, replaced it with new, still running cold on cylinder 5. Put a plug in wire and grounded plug, there was spark. Checked resistance on injector and it was 21, and voltage to injector was .45 which matched other injectors. So now the only thing it could be is spark is not strong enough. Thanks a bunch for any help you can lend.
