Need valve body removal help.
SANTEEN said:
Dude, it's a messy ass job.:D
Yes it is! I installed a drain plug in my pan so that I could drain it easily when I get the urge to play around with the valve body. I usually drain the pan, let it drip for an hour or so, and then take off the filter, loosten up the valve body bolts but leave the valve body hanging down on the bolts, and then put the pan back on with 2 bolts. I let it drip over night into the pan and then drain the pan again. After removing the pan the second time, most of the fluid is out. It still wants to drip on my forehead though....
santeen just bathes in it heheheh
transgo shift kit
What should I expect to pay to get this installed if I take it to a transmission shop.Also would most shops have no problem installing it since it is a diesel modified trans.:confused:
