Need Wheels
tinygiants
Belfair WA
I am looking for some wheels that fit these Tires. I am having trouble finding anything in our lug pattern. I would like to find a set for the fronts as well.
I've looked at doing the same thing. I think your only option is to buy some wheels that look like the factory wheels off eBay in 20" and have them widened. Mopar1958 has a guy that can widen them to what ever size you need.
My builder would not like that idea, as the backspacing would leave a large portion of the wheel unsupported. I hope there is another option. Other wise I will have to change the lug pattern on the axle. Then I will never find a match for the fronts.
Even if you cahnge the bolt pattern the backspacing won't change unless I'm missing something. Sounds like you need to narrow the rear end if you're worried about backspacing.
I am sorry. But you are right. I am looking into getting a 4 link with a narrowed rear. I should have shared that info up front. I am looking to see what rims are available so I can determine how much narrowing will be required.
