SergioL.
I recently purchased a near new X-Metal Gen 1 shifter. I researched as much as I could online but could not find any instructions on the install, so I just winged it. I put silcone on both sides of the spacer and the gasket that goes inbetween it and the base of the shifter, when I finished I took it for a 25 mile test drive and checked for leaks. I did not like the look of the X-Metal handle or the fact that it is straight. I had already shortened the factory handle 2 3/8" and removed the vibration dampener of the Hurst which improved the feel a lot. But, I would still miss 3rd on occasion and I even missed 4th once which is when I started hunting for an upgrade. This has never happened to me in any other vehicle, I feel like the stock shifter in a foxbody is better than these Hursts! I decided to keep the stock handle and I redrilled it so it could bolt up to the X-metal and I turned it so it angles toward the driver instead of away like it is stock. I have it bolted up with the 2 bolts that come with the X-Metal and an extra Grade 8 bolt/nut/lock washer, all with Loctite. It is about as short of a shifter you can run on an '04/'05 and probably impossible in an '06. I am in love all over again with the truck. It feels like I'm driving a car, it damn near goes into 3rd by itself, and it is actually quieter than the Hurst with the Vibration Dampener removed despite the fact I'm running Pennzoil Synchromesh in the trans. I was worried I was going to have to mod it some more after the initial test drive to quiet it down.
I absolutely love the shifter and I know people have removed these to upgrade to newer shifters, I can only imagine what those feel like. I'm 5'8," have my seat slightly leaned back and I can reach the shifter just fine:
1st
3rd
5th
Can somebody school me on X-Metal SRT 10 shifters?
I read the Gen 1's are just B&M SRT 10 Viper shifters modified to work on our trucks. Is this true?
How many different generation X-Metal shifters are there?
Why did they go out of business?
1st
3rd
5th
