New member need help !!
teamvilliard
Hi guys
I had an 05 srt10 auto with the 8.3 , after having problem with nitrous I decided to built another motor either n/a or with a blower , thinking about roe or paxton ...
So right now I have the stuff that go on the 8.3 but the shortblok is gone , so i'm thinking about buying and 8.4 shortblock and put my 8.3 head (ported ) and erevything on , just wondering is this would fit together ?
is you have another route to suggest please comment !!what would be my best option to get about 6-700 to the wheel? this is not a dayli driver just a summer truck and want it to be more reliable than the nitrous ,
thanks for the helps guys !
If I was you I would not try to install the 8.4, I would find another 8.3 and have it built. Then as for a blower goes, I would buy the Procharger from JMB.
Thanks for the responses !!
So it fit but with some tricks or its a complete bolton process?
Also what is the safe rwhp limit for those motor with the blower with the stock short block?
I already destroy 2 shortblock so i would like to do it right this time .
thanks again!
If you are going for the 3rd strike, go ahead and forge the internals while there. You can throw anything at it after that so long as the timing and A/F is on. As far as more power, go with a Procharger and a lil meth so you can run a tad more timing under boost.;)
Methanol is a bandaid and bandaids fall off when you aren't looking!! Talk with your builder and set mechanical compression to match maximum boost! Save alot of problems later! Like prof preach's , Plan your build the build your plan!!
