Allen6piranna said:
Hey this Allen I became a member a while back knowing I was going to own the best truck in the world period..... I bought Blaines Silver Viper SRT and have a question for everybody that reads this. I have had it for three weeks now and after giving it a nice detail the engine light came on giving the code 1486 pinched evac hose!!! Has anybody came across this code if so please respond, it is much appreciated.
Thanks,
Allen6piranna
Engine codes
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW - SRT10
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH - SRT10
P0051-O2 SENSOR 2/1 HEATER CIRCUIT LOW - SRT10
P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH - SRT10
P0071-AMBIENT/BATTERY TEMP SENSOR PERFORMANCE - SRT10
P0107-MAP SENSOR VOLTAGE TOO LOW - SRT10
P0108-MAP SENSOR VOLTAGE TOO HIGH - SRT10
P0111-INTAKE AIR TEMP PERFORMANCE - SRT10
P0112-INTAKE AIR TEMP SENSOR VOLTAGE TOO LOW - SRT10
P0113-INTAKE AIR TEMP SENSOR VOLTAGE TOO HIGH - SRT10
P0117-ENGINE COOLANT TEMP SENSOR VOLTAGE TOO LOW - SRT10
P0118-ENGINE COOLANT TEMP SENSOR VOLTAGE TOO HIGH - SRT10
P0121-TP SENSOR VOLTAGE DOES NOT AGREE WITH MAP - SRT10
P0122-THROTTLE POSITION SENSOR #1 VOLTAGE TOO LOW - SRT10
P0123-THROTTLE POSITION SENSOR #1 VOLTAGE TOO HIGH - SRT10
P0125-CLOSED LOOP TEMP NOT REACHED - SRT10
P0131-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO LOW - SRT10
P0132-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO HIGH - SRT10
P0133-O2 SENSOR 1/1 SLOW RESPONSE - SRT10
P0135-O2 SENSOR 1/1 HEATER FAILURE - SRT10
P0136-O2 SENSOR 1/2 HEATER CIRCUIT MALFUNCTION - SRT10
P0137-O2 SENSOR 1/2 CIRCUIT VOLTAGE TOO LOW - SRT10
P0138-O2 SENSOR 1/2 CIRCUIT VOLTAGE TOO HIGH - SRT10
P0139-O2 SENSOR 1/2 SLOW RESPONSE - SRT10
P0141-O2 SENSOR 1/2 HEATER FAILURE - SRT10
P0151-O2 SENSOR 2/1 CIRCUIT VOLTAGE TOO LOW - SRT10
P0152-O2 SENSOR 2/1 CIRCUIT VOLTAGE TOO HIGH - SRT10
P0153-O2 SENSOR 2/1 SLOW RESPONSE - SRT10
P0155-O2 SENSOR 2/1 HEATER FAILURE - SRT10
P0157-O2 SENSOR 2/2 CIRCUIT VOLTAGE TOO LOW - SRT10
P0158-O2 SENSOR 2/2 CIRCUIT VOLTAGE TOO HIGH - SRT10
P0159-O2 SENSOR 2/2 SLOW RESPONSE - SRT10
P0161-O2 SENSOR 2/2 HEATER FAILURE - SRT10
P0171-1/1 FUEL SYSTEM LEAN - SRT10
P0172-1/1 FUEL SYSTEM RICH - SRT10
P0174-2/1 FUEL SYSTEM LEAN - SRT10
P0175-2/1 FUEL SYSTEM RICH - SRT10
P0197-ENGINE OIL TEMPERATURE SENSOR VOLTAGE TOO LOW - SRT10
P0198-ENGINE OIL TEMPERATURE SENSOR VOLTAGE TOO HIGH - SRT10
P0201-INJECTOR #1 CONTROL CIRCUIT - SRT10
P0202-INJECTOR #2 CONTROL CIRCUIT - SRT10
P0203-INJECTOR #3 CONTROL CIRCUIT - SRT10
P0204-INJECTOR #4 CONTROL CIRCUIT - SRT10
P0205-INJECTOR #5 CONTROL CIRCUIT - SRT10
P0206-INJECTOR #6 CONTROL CIRCUIT - SRT10
P0207-INJECTOR #7 CONTROL CIRCUIT - SRT10
P0208-INJECTOR #8 CONTROL CIRCUIT - SRT10
P0209-INJECTOR #9 CONTROL CIRCUIT - SRT10
P0210-INJECTOR #10 CONTROL CIRCUIT - SRT10
P0300-MULTIPLE CYLINDER MIS-FIRE - SRT10
P0301-CYLINDER #1 MISFIRE - SRT10
P0302-CYLINDER #2 MISFIRE - SRT10
P0303-CYLINDER #3 MISFIRE - SRT10
P0304-CYLINDER #4 MISFIRE - SRT10
P0305-CYLINDER #5 MISFIRE - SRT10
P0306-CYLINDER #6 MISFIRE - SRT10
P0307-CYLINDER #7 MISFIRE - SRT10
P0308-CYLINDER #8 MISFIRE - SRT10
P0309-CYLINDER #9 MISFIRE - SRT10
P0310-CYLINDER #10 MISFIRE - SRT10
P0320-NO CRANK REFERENCE SIGNAL AT PCM - SRT10
P0325-KNOCK SENSOR 1 CIRCUIT - SRT10
P0330-KNOCK SENSOR 2 CIRCUIT - SRT10
P0340-NO CAM REFERENCE SIGNAL AT PCM - SRT10
P0351-IGNITION COIL #1 PRIMARY CIRCUIT - SRT10
P0352-IGNITION COIL #2 PRIMARY CIRCUIT - SRT10
P0353-IGNITION COIL #3 PRIMARY CIRCUIT - SRT10
P0354-IGNITION COIL #4 PRIMARY CIRCUIT - SRT10
P0355-IGNITION COIL #5 PRIMARY CIRCUIT - SRT10
P0420-1/1 CATALYTIC CONVERTER EFFICIENCY - SRT10
P0432-2/1 CATALYTIC CONVERTER EFFICIENCY - SRT10
P0441-EVAP PURGE FLOW MONITOR - SRT10
P0442-EVAP LEAK MONITOR MEDIUM (0.040) LEAK DETECTED - SRT10
P0443-EVAP PURGE SOLENOID CIRCUIT - SRT10
P0455-EVAP LEAK MONITOR LARGE LEAK DETECTED - SRT10
P0460-FUEL LEVEL SENDING UNIT NO CHANGE OVER MILES - SRT10
P0462-FUEL LEVEL SENDING UNIT VOLTS TOO LOW - SRT10
P0463-FUEL LEVEL SENDING UNIT VOLTS TOO HIGH - SRT10
P0500-NO VEHICLE SPEED SIGNAL - SRT10
P0505-IDLE AIR CONTROL MOTOR CIRCUITS - SRT10
P0522-OIL PRESSURE CIRCUIT LOW - SRT10
P0523-OIL PRESSURE CIRCUIT HIGH - SRT10
P0601-PCM INTERNAL CONTROLLER FAILURE - SRT10
P0622-GENERATOR FIELD NOT SWITCHING PROPERLY - SRT10
P0645-A/C CLUTCH RELAY CIRCUIT - SRT10
P0801-REVERSE GEAR LOCKOUT CIRCUIT OPEN OR SHORTED - SRT10
P1195-O2 SENSOR 1/1 SLOW DURING CATALYST MONITOR - SRT10
P1196-O2 SENSOR 2/1 SLOW DURING CATALYST MONITOR - SRT10
P1281-ENGINE IS COLD TOO LONG - SRT10
P1282-FUEL PUMP/SYSTEM RELAY CONTROL CIRCUIT - SRT10
P1294-TARGET IDLE NOT REACHED - SRT10
P1296-NO 5-VOLTS TO MAP SENSOR - SRT10
P1297-NO CHANGE IN MAP FROM START TO RUN - SRT10
P1388-AUTO SHUTDOWN RELAY CONTROL CIRCUIT - SRT10
P1389-NO ASD RELAY OUTPUT VOLTAGE AT PCM - SRT10
P1391-INTERMITTENT LOSS OF CMP OR CKP - SRT10
P1398-MIS-FIRE ADAPTIVE NUMERATOR AT LIMIT - SRT10
P1486-EVAP LEAK MONITOR PINCHED HOSE FOUND - SRT10
P1492-AMBIENT/BATTERY TEMPERATURE SENSOR VOLTAGE TOO HIGH - SRT10
P1493-AMBIENT/BATTERY TEMPERATURE SENSOR VOLTAGE TOO LOW - SRT10
P1494-LEAK DETECTION PUMP SWITCH OR MECHANICAL FAULT - SRT10
P1495-LEAK DETECTION PUMP SOLENOID CIRCUIT - SRT10
P1499-HYDRAULIC FAN SOLENOID CIRCUIT - SRT10
P1594-CHARGING SYSTEM VOLTAGE TOO HIGH - SRT10
P1598-A/C PRESSURE SENSOR VOLTAGE TOO HIGH - SRT10
P1599-A/C PRESSURE SENSOR VOLTAGE TOO LOW - SRT10
P1682-CHARGING SYSTEM VOLTAGE TOO LOW - SRT10
P1687-NO CLUSTER BUS MESSAGE - SRT10
P1695-BUS MESSAGE FROM BODY CONTROL MODULE - SRT10
P1696-PCM FAILURE EEPROM WRITE DENIED - SRT10
Trans codes
P0711-TRANS TEMP SENSOR, NO TEMP RISE AFTER START (DIESEL)
P0711-TRANS TEMP SENSOR, NO TEMP RISE AFTER START (GAS)
P0712-TRANS TEMP SENSOR VOLTAGE TOO LOW (DIESEL)
P0712-TRANS TEMP SENSOR VOLTAGE TOO LOW (GAS)
P0713-TRANS TEMP SENSOR VOLTAGE TOO HIGH (DIESEL)
P0713-TRANS TEMP SENSOR VOLTAGE TOO HIGH (GAS)
P0720-LOW OUTPUT SPEED SENSOR - RPM ABOVE 15 MPH (DIESEL)
P0720-LOW OUTPUT SPEED SENSOR - RPM ABOVE 15 MPH (GAS)
P0740-TORQ CON CLU, NO RPM DROP AT LOCKUP (GAS)
P0743-TORQUE CONVERTER CLUTCH SOLENOID/TRANS RELAY CIRCUITS
P0748-PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS (DIESEL)
P0748-PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS (GAS)
P0751-O/D SWITCH PRESSED (LO) MORE THAN 5 MINUTES
P0753-TRANS 3-4 SHIFT SOL/TRANS RELAY CIRCUITS (GAS)
P0783-3-4 SHIFT SOL, NO RPM DROP AT LOCKUP (GAS)
P0850-P/N SWITCH PERFORMANCE (DIESEL)
P0868-GOVERNOR PRESSURE SENSOR VOLTS TOO HI (DIESEL)
P0869-GOVERNOR PRESSURE SENSOR VOLTS TOO LOW (DIESEL)
P0882-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT LOW (DIESEL)
P0883-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT HIGH (DIESEL)
P0973-TRANSMISSION OVERDRIVE CIRCUIT VOLTAGE TOO LOW (DIESEL)
P0974-TRANSMISSION OVERDRIVE CIRCUIT VOLTAGE TOO HIGH (DIESEL)
P1740-TCC O/D SOL PERFORMANCE (DIESEL)
P1740-TCC O/D SOL PERFORMANCE (GAS)
P1749-TRANSMISSION THROTTLE VALVE POSITION SENSOR CIRCUIT LOW
P1750-TRANSMISSION THROTTLE VALVE POSITION SENSOR CIRCUIT HIGH
P1751-TRANSMISSION THROTTLE VALVE POSITION MINIMUM RANGE PERFORMANCE
P1752-TRANSMISSION THROTTLE VALVE SPAN PERFORMANCE
P1753-TRANSMISSION THROTTLE VALVE MECHANICAL PERFORMANCE
P1754-TRANSMISSION THROTTLE VALVE ACTUATOR STUCK
P1755-TRANSMISSION THROTTLE VALVE CONTROL CIRCUIT
P1756-GOV PRESS NOT EQUAL TO TARGET @ 35 - 40 PSI (DIESEL)
P1756-GOV PRESS NOT EQUAL TO TARGET @ 35 - 40 PSI (GAS)
P1757-GOV PRESS ABOVE 3 PSI IN GEAR WITH 0 MPH (DIESEL)
P1757-GOV PRESS ABOVE 3 PSI IN GEAR WITH 0 MPH (GAS)
P1762-GOV PRESS SENSOR OFFSET VOLTS TOO LOW OR HIGH (DIESEL)
P1762-GOV PRESS SENSOR OFFSET VOLTS TOO LOW OR HIGH (GAS)
P1763-GOVERNOR PRESSURE SENSOR VOLTS TOO HI (GAS)
P1764-GOVERNOR PRESSURE SENSOR VOLTS TOO LOW (GAS)
P1765-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT (GAS)
P1899-P/N SWITCH STUCK IN PARK OR IN GEAR (GAS)
P2769-TRANSMISSION TCC CONTROL CIRCUIT LOW (DIESEL)
P2770-TRANSMISSION TCC CONTROL CIRCUIT HIGH (DIESEL)
ABS codes
BODY STYLE MISMATCH - 85
BRAKE SWITCH CIRCUIT - 81
ECU INTERNAL FAILURE -75
EXCESSIVE DUMP TIME - 69
FOUNDATION BRAKE - 78
INTERMITTENT SIGNAL FROM LEFT FRONT SENSOR - 27
INTERMITTENT SIGNAL FROM REAR SENSOR - 37
INTERMITTENT SIGNAL FROM RIGHT FRONT SENSOR - 23
INTERNAL MAIN RELAY OPEN - 65
INTERNAL MAIN RELAY SHORTED - 66
LEFT FRONT ISOLATION SOLENOID SHORTED - 47
LEFT FRONT DUMP SOLENOID OPEN - 46
LEFT FRONT DUMP SOLENOID SHORTED - 48
LEFT FRONT ISOLATION SOLENOID OPEN - 45
LEFT FRONT SENSOR OPEN - 25
LEFT FRONT SENSOR SHORTED - 90
MISMATCHED VIN - 84
NO SIGNAL FROM LEFT FRONT SENSOR - 26
NO SIGNAL FROM REAR SENSOR - 36 NO SIGNAL FROM RIGHT FRONT SENSOR - 22
NUMBER OF TINE RING TEETH OUT OF RANGE - 82
PUMP MOTOR CIRCUIT OPEN - 67
PUMP MOTOR STALLED - 68
RAM READ/WRITE - 71
REAR ISOLATION SOLENOID SHORTED - 53
REAR DUMP SOLENOID OPEN - 54
REAR DUMP SOLENOID SHORTED - 54
REAR ISOLATION SOLENOID OPEN - 51
REAR RESET SWITCH CLOSED - 63
REAR SENSOR OPEN - 35
REAR SENSOR SHORTED - 93
RIGHT FRONT ISOLATION SOLENOID SHORTED - 43
RIGHT FRONT DUMP SOLENOID OPEN - 42
RIGHT FRONT DUMP SOLENOID SHORTED - 44
RIGHT FRONT ISOLATION SOLENOID OPEN - 41
RIGHT FRONT SENSOR OPEN - 21
RIGHT FRONT SENSOR SHORTED - 91
ROM CHECKSUM - 72
SYSTEM CONTROL MODE TIMEOUT - 74
SYSTEM OVER/UNDER VOLTAGE - 96
TIRE REVS PER MILE OUT OF RANGE - 83
Well, it is on the list, but what to do about it is not :dontknow:
PM Robert at TheMoparConnection he may know
