well fellas I have made a good contact today for yuns and need a little bit of what ya'll think.
I can get us plug wires now in blue black yellow purple and red
interested yet?
gets better
they will retail for $165 plus the shipping, but will get you guys intially for $150 for a short time
they are sheathed and good for 1400 degrees/1 year warranty
they will not work in oem wire stands due to the sheathing they are 10mm but they have billet wire separators available . but they are only separators
interest sparked yet?
well I am sending him my coils also to see if they can do a high performance replacement coil for us:rock:
here is some info on the wires
heat resistant sleeving that provides superior
protection to the plug wires from the extreme underhood temperatures generated by the exhaust. The sleeving
is a non-flammable heat treated glass braid, much like the type used on todays ovens. The unique sleeving on provides heat protection up to +1400° F and offers excellent resistance to moisture and chemicals.
they are custom fit, so no assembly is required. Each wire is numbered on both ends for the correct cylinder
making installation, removal and re-installation quick and easy. No cutting, splicing or crimping is required like
other aftermarket wire sets.
they have a durable and long lasting silicone jacket and insulation. Heat shrink applied between the boot and
the sleeving keeps dirt and moisture away from wire terminals. Dielectric grease is included with all sets and should
be applied to the spark plug boots to prevent voltage leakage and keep wire terminals and boots from sticking to
the plug.
the wires are a spiral core wire which means they have a stainless steel wire wrapped around a magnetic core.
This is a suppression type wire so there is no electronic interference with the radio or computer and they work well
with delay boxes and stutter boxes. A spiral wound core also offers extremely low resistance of 300 - 350 Ohms
per foot for optimum spark travel.
interested yet?
gets better
the plug.
