The next problem that has surfaced is the brakes seem to be sticking when they get hot. You can feel the resistance when you let off the gas. It is very noticeable. I jacked up the front and couldn't even rotate the left wheel by hand. I could rotate the right wheel but it was pretty hard to do. After sitting over night it is back to normal until braking a few times again.
I tried cracking the bleeder valve while it was like this and a little brake fluid came out but I still couldn't rotate the wheel. What do you guys think could be the problem?? Caliper binding up or is there some type of valve involved between the master and the calipers that could cause this?
