new projector headlights and projector fogs
ctsrt10
A few days ago i got my headlights from an other memeber and installed them needless to say it was easy. but for one light where the ground for the halo was missing. they are sending me a new one. but i took pics to share.
HEADS AND FOGS OFF:
PARK AND HALOS ON:
ALL LIGHTS ON:
wow that looks sweet... didn't you have to remove the bumper to get the fogs in??? how difficult was that??
noway the bumper stays on the truck. heres the easy way, when you have the headlights out sneek your hand hand low take out the 3 zip style screws and slip out the light between the tire and lower plastics. (our trucks are the only one with plastics that block the fogs) if you have an reg old 02-08 ram you can do right from under the truck. once the fog light was out i notice that i need the black wedges that lines up the fogs (three more bolts) i should took pics but wasn't thinking about it.
I have an 06 and it has a belly pan, attached with 15 screws. I haven't taken it off but I assume access to the fog light housings is easy once it is removed. Also, my belly pan has access holes in it so that the fog lamps can be changed without dropping the pan. Is this common for all SRT-10's?
I am looking to get those exact same headlights maybe a slightly different variation where the parking lamp goes but I notice there are two headlights in each assembly. What bulbs go in these? I take it you can not reuse what is in the stock headlight assembly. I am currrently using the SilverStar Ultras.
here h1 lights and they dont make sliverstars ultras in that,as far as installing them in an 06 its the same thing take headlight out and take 3 bolts and slide it across the valance where the hole is. oh yea slvrsnake p.m you number so i can call you next time we have a meet since your in the dirty jersy lol
I have a set of projectors for mine, but when installing the HID, you can hardly see the road. What make are the projector & fogs you got? Where did you get them? Thanks!
i got them from an other memeber on here who didnt want them. he got them from k2 motors?
but to see the road theres a reflector inside the projector glass that has to be removed to achive the correct beam its kinda a pain in the ass but thats what you have to do. its the same thing thats in out stock lights that little chrome thing. hope the info helps i would give more info but thats all i have there not even a phone number on his old invoice or web site so i think there ebays. but all them projector lamps are the same.
Heres my cardomain to see my other work
http://www.cardomain.com/id/01ctmax
