Blakewilder
Man.....what a difference. The truck breaks traction at barely half throttle with street tires on! It is WAYYY more power hittin the ground with the Power-Lock. Install was a snap. The Power-Lock is a little noisy around corners but not bad at all. Test fitted the slicks and was shocked at the difference. Im going to the track SOON! I do have a problem though....the new studs are Nascar studs and are 5/8" instead of the usual 9/16" studs. On my factory wheels the new lugnuts fit fine...BUT, Im running aftermarket wheels that the lugnuts recess into. This poses a problem because the new lugnuts hit the recess hole for the stud. I CANNOT find any lugnuts with a 5/8" bore and a slim outer diameter...they just dont exist! Im trying to take the old 9/16" lugs and have them drilled and tapped but the 2 tool and die places Ive gone to say that the metal is too hard and will not be drillable.....
ANY IDEAS?????
ANY IDEAS?????
