Our new carbon driveshafts are now available, $1000 plus shipping
here is a few pics
oem shaft wieght 15 lbs 12 ozs
carbon shaft weight 15lbs 15 ozs
the benifits of carbon
safety, unlike a steel or aluminum shaft, a carbon shaft will broom out or shatter into small portions , this keeping from major damage happening to more important components
higher rpms available from smoother rpms
higher spring and torsional rate than steel
less of a shock load to components
smoother shifting, meaning quicker shifts
due to a higher spring rate, a quicker or lower 60ft times
carbon actually will twist then spring back resultin in lower 60ft times
eliminates high rpm vibrations resulting in more hp and smoother engine operation at
high rpms
longer transmission and rear axle life
during hard shifts the shaft will actually wrap and aborb alot of the "hit" from hard shifts
resulting in quicker shifts and longer transmission life
t7075 billet ends, with a contiuous carbon weave
steel yokes
balance tested to 9500 rpms
ready for orders
here is a few pics
high rpms
steel yokes
ready for orders
