Anyone know of this Wideband sensor? Anybody use it?
NGK Powerdex AFX - Air Fuel Ratio Monitor - Wideband o2
Accurate Information
The NGK AFX Air Fuel Ratio Monitor is the most affordable “true†wideband technology to date. Many low-cost air-fuel ratio monitors do not use wideband sensors; they simply manipulate a standard narrow-band oxygen sensor signal with rough inaccurate data resulting in only marginal success. The NGK AFX Air Fuel Ratio Monitor reads air fuel ratio (AFR) values from 9.0 to 16.0 with a resolution of 0.1.
True Wideband Technology
The NGK AFX is a true air/fuel monitor that senses exhaust oxygen, carbon monoxide, hydrogen, and hydrocarbons in the exhaust and calculates real time air fuel ratio (AFR). Air Fuel Ratio is a crucial parameter that dictates horsepower and engine performance. Performance enthusiasts and tuners can use Air Fuel Ratio information to make adjustments to the fuel delivery system (carburetor, fuel injection) to help achieve the maximum horsepower available from their engine. The AFX is compatible with both Bosch LSU and NTK UEGO (wideband) sensors without any changes in hardware or programming and offers superb accuracy (comparable to some laboratory grade systems).
Cost Effective
Traditionally these types of tools commanded price tags in the thousands of dollars putting them out of reach for most enthusiasts and amateur/grassroots racers. NGK’s advances in technology have made this highly accurate tool affordable.
Experience
NGK-NTK is the world leader in exhaust gas sensors and sensor related technology. They supply OEM oxygen sensor technology to a huge range of Asian, European, and domestic auto manufacturers.
Analog Compatible
The NGK AFX has a 0 ~ 5V, linear analog output for AFR that can be used as an input to an engine controller, data acquisition system, or analog gauge with 0 to 5 volt input.
Complete Wideband O2 Kit
The Air Fuel Ratio Monitor Kit is a complete wideband O2 kit. This package comes:
* Digital display controller (~3.4in x 2.7in x 1.3in)
* 13’ wiring harness
* Wideband oxygen sensor
* Exhaust boss & plug
* Comprehensive air-fuel ratio tuning manual
This is all you need to accurately read air fuel ratio values.
Cost Effective
Experience
Analog Compatible
