Nitrous plate
vallessrt10
Does anyone know where I could get a nitrous plate for our trucks?
Taylor Helix Tower Power
You can use a Taylor Helix Tower Power spacer available from JEGS. It is 1" thick. You can machine it for nitrous nozzles and also use two nozzles, one for each plenum. It can also be machined to match the throttle bore either single oval or dual bores. Cost 100.00 and is nicely polished. Check my personal site under members list and you can see one with four nozzles. Matches well with the aftermarket throttle bodies.
Nitrous
By the way I might have two nitrous systems for sale. One with a four nozzle wet system on the throttle body. The second with 10 direct port nozzles on the intake manifold. The manifold has pop off valves. Both systems have never been used but were installed as a show truck. 15 lb. bottles with openers and heaters. I'll post them on this sight when they are available.
Nitrous Kits
Don't know any pricing yet. Will have to divide my setup into two kits and see what parts are in each kit. I'll list them on this web site when done. I have computers, relay assemblies, purge setups, fuel pumps, filters and tanks with heaters and bottle openers that are part of the setups. Also a separate fuel cell and CNC machined mounting brackets and solenoid mounting manifold that was made for the viper intake manifold.
