Snakes709
OK im confused on one part of my setup. I have a Zex system and i finally got around to installing the TC Window Switch. Got it all wired up and i tapped into the blue/white wire for the tach signal (coil control #4)
I'm confused on the first step of the programming....
Step 1: TACH signal set-up:
Number display B and C should be set to the chart below (Number display A is not used in this step):
0 0 = individual coil per cylinder systems where the TACH wire is connected to the coil
0 1 = coil packs that fire in pairs (waste spark systems) and the TACH wire is connected to the coil
0 2 ~ 1 2 = number of engine cylinders, from 2 to 12, where the TACH wire is connected to the tach from the engine electronic controller or distributor
Now am i entering 10 for the amount of cylinders we have or am i entering something else for the coil pack i tapped into? I took a guess and put 10, just wanna make sure I am right.
Also what have you guys put your settings on...the skip shift confuses me so i put 0 to turn it off and i set the activation at 3000rpm and my deactivation at 5900.
