Nitrous Setup
which ZEX kit is everyone using?
I have been told to use the 82176 Hemi Truck, but a rep from ZEX stated I should use the 82023 kit.
Thanks
Adam
I'm using a universal kit, and just buying the pieces i need as i go. Orginially this was suppose to be for my 370z.
I pieced my kit together as well, started out with parts to a universal kit.
Thanks for the input.
I think I'm going to pull it off my Charger and use it on the Ram. I ran the juice for 2 years in my charger and worked very well.
Which wire did you tap into for the TPS, for wide open activation?
Installing a LC-1 A/F gauge this coming weekend.
Thanks again
Adam
I ran a micro switch to the pedal and a hand held momentary switch on our 5.7 Charger and the wife ran an 11.9 two weeks ago. Heard of a lot of problems with the zex controller, didn't want to chance the TPS set up they use.
I tapped into the white wire on the TPS by the throttle body. I'm actually doing some of the wiring today. Just reading over the manual. Gotta tap into that wire, program the NMU and then disconnect the tap and connect the window switch to it. Its going to be a bitch running the wires inside the cab. Anyone know a quick way off getting the center seat out of the QC? I'm seeing bolts under the frame that the seat is on but its a PITA to get to them. Also gotta thank tony for showing me a picture of where the TACH Signal wires are...lol.
Is this different on a 04 rc? I do not have a white wire on the tps.
Would you mind sharing which wire for the tach? and where to find?
Just found in the manual that the pink/yellow is the 5volt wire, is this correct?
Thanks, just got the kit.
I got pretty much the same system setup as you did Snakes (ZeX 100 shot). Only my jets shoot into the underside of the throttlebody. And like you I haven't sprayed yet either. :eek:What's probably silly is I'm too damn worried about trying it out. I've only hit the purge every now and then to see the pretty red glow. :dontknow:I still want it dyno-tuned before I activate it though.
Thats a real nice bottle setup bracket and valves look cool. Where can I get a setup like that.
Anthony, you just have a bad a$$ set up. Love that paint job on the bottles. Looks better in person.
pretty sure the tps is the same for all the trucks. I'll post up the picture of the tach signal wire later, busy right now. Its located on the ecm on the left hand side of the engine bay where all the wires are. Just cant remember which ones off the top of my head.
you will feel the 100 shot but it's really not that noticeable. I doubt you'd feel a 55 shot at all. I used a 175 shot and that was fun.
Thanks for the link.
Brown/orange and middle for TPS sensor to white.
All works, so far.
Thanks again
Adam
