beastinside
I have an 05 QC, stock. I've been getting a no bus code in my odometer when I drive my truck. When the code comes up all the gauges stop working, radio wont work properly and I noticed my mileage wasn't registering. When I park and set the E-brake, no bus goes away, gauges function normally and the radio works again. This started as just an intermittent problem, then became an everyday thing. Sometimes while driving if I hit a bump the code would go away and everything would work fine, until I hit another bump then the code would come back and gauges would stop working.
I took my truck to the dealer I bought it from to have them work on it. They've had it for 2 weeks trying to figure out the problem. Apparently the aftermarket alarm was causing some sort of communication problem with the computer. They're telling me the truck needs a new PCM but they aren't able to track one down. So I have two questions for the viperheads out there.
1. Does any of this make since?
2. Where can I or the dealer get a new PCM for my truck?
Thanks in advance.
Thanks in advance.
