NO COMPRESSION in #1 SRT10
Hi all, I need advice.
I have a 2005 SRT10 Ram with 40,000 miles on it.
Started making rapid tapping sounds but not all the time.
Engine light is on.
Error codes are:
A. #1 cylinfer missfiring
B. O2 sensor
C. Charcoal canister by fuel tank.
Pulled top end off engine
Here is what I know so far.
A. No compression in #1 cylinder - only 5 PSI
B. The valves and top of #1 piston look very silvery and extra clean compared to the others firing good.
C. Cylinder wall looks very clean.
D. Valves and spring all seating good and vacuum test good from head shop.
E. Poured oil into #1 cylinder and did not leak into crank case in 48 hours.
F. cam and lifters look good.
The mechanic now wants to pull the #1 piston next and inspect it closer.
I looked at the engine oil and its not that bad with a few silver specs.
Where is the leak? I am very perplexed any thoughts?
Engine light is on.
Error codes are:
B. O2 sensor
