nycstev
Here is a repeat of yesterdays dyno results which raised a few questions. Contacted Sean and here's what he said:
Hi Steve,
Safe, which means rich, is usually 12.0:1 AF ratio.
Lean is mean and 12.8-13.0 is powerful.
If the motor is really efficient and has the right temperature plugs, it can take 13.0.
Remember, this is read after the fuel is burned and is an indication of how much it burned.
Most people run richer to cover variances.
’d say get it broken in, then maybe turn up the fuel pump booster to max and have the injector pulse turned up a bit. Seems to be plenty rich at the very top, so there should be room to add fuel at lower RPM’s.
Maybe shoot for 12.2, which should still be plenty safe.
Best regards,
Sean
Roe Racing
Hi Steve,
Best regards,
Sean
Roe Racing
