what is the ez'est what to remove the pass' side upstream o2 sensor ?
Bone said:Unclip it at the harness - easy
Then unscrew it from the pipe with a wrench. May take some PB Blaster or oil to help remove it. It should come right off.
FerrariTruck said:well if your a smaller guy like myself you can crawl in the engine compartment.
5'8" 170
place your right foot on the frame where the upper control arm is. your left foot on the frame just forward of the upper control arm mount. you can have to angle your foot like a girl to get it down there. (or you can put your left knee on the intake) then just reach back behind the motor and unplug it
Tooth pick you should have no problem.VIPER said:![]()
im 6'5" 275 lbs
but thanks for the idea - im up for anything, that dont envolve my arm gettin stuck again
