oem camshaft specs
Ironhead
h-town
sitting here bored and have a question ,,,and need an qualified response lol,,
question on oem cam specs ,,got a friend itching that wants to do a cam swap like i did but wants to know the following
-------------------------------------intake ------ exhaust
Duration---------
duration @.050 lift------------------- -----
Valve lift -------- ----
Lobe lift--------- ----
---------------------------------------open ------------close
intake --------------------------------------btdc --------------abdc
exhaust------------------------------------ bbdc -------------atdc
lobe center angle =
can anyone here fill in the numbers for the stock viper 05 camshaft above,,,,paste and copy and tell the these numbers he is drivin me nuts
Duration---------
lobe center angle =
Does this help at all?
cant read it all hell im old and blind in one eye;)
Yeah, It's not a very good copy. Did you try Zoom? It's kinda out of focus, But you might be able to read it. Or you can have some young eyes take a look.:p
well he has a print out from comp cam and wants to compair numbers it comp cams spec card i guess you call it,,,he down loaded the page from the o he wants to compare all the numbers for a oem stock to a hr 264 cam ,numbers to numbers,,there is a page you can print out and use to write it down on ,,anywho im not suppose to be drinkin opps ,,
Ironhead said:
well he has a print out from comp cam and wants to compair numbers it comp cams spec card i guess you call it,,,he down loaded the page from the o he wants to compare all the numbers for a oem stock to a hr 264 cam ,,,there is a page you can print out and use to write it down on ,,anywho im not suppose to be drinkin opps ,,
Tony ( Stinker ) posted that up one night, I had it in my recycle bin. He probably has a better copy.
FATJACK said:
Old Fart!!!!:D :D
at least you are admiting it jack lol:D
im going to scan this thing at work and see who can fill in the blanks
Hey Bro, Is this a little better?
