oil and spark plugs help
DRamSrt10
Ashland, Ma
hey, I'm going change my oil and spark plugs but what I want to make sure that the oil is mobil 1 synthetic 10w-30 correct? and which is the better spark plug that would work good on truck? I know its most common spark plugs but I want a little better performance with high qualify
I'm pretty sure you will find that the '04's were 13W30,and the '05's went to the 0w50 !!!Had that issue with Naples Dodge when I first bought my truck !!!
ok I found that mine is 10w-30 too I checked the oil cap but what abt spark plugs? just make sure
6pakattack said:
I'm pretty sure you will find that the '04's were 10W30,and the '05's went to the 0w50 !!!Had that issue with Naples Dodge when I first bought my truck !!!
04's - 10w30
05/06 - 0w40
Depending on your mods, the NGK's are the best route. It all depends on your mods on what heat range you want to go. Too cold of plugs wont gain you any power, there will cause your truck to run like crap though :D
