OIL IN ROE?
Yellow venom
Boosted Venom
Edmonton,Alberta,Canada
Is it just engine oil used in the ROE SC? If so whats everryone running (brand and weight) and how often do you need to change it? Thanks in advance:rock:
The instructions say use a multi grade synthetic. The factory fill is Castrol 5W-50 Syntec. If it looks clean, it need not be changed.
From the ROE Website...
What kind of maintenance does the Supercharger add?Next to none. The oil in the unit does not come from the engine oiling system, which gets contaminated from blowby and the combustion process. Therefore, the compressor oil stays cleaner and in better condition longer. We suggest the case oil level be checked at each engine oil change. The oil color will be the first indication that a change is due, which should be at approximately 50,000 miles.
you can call pse superchargers too they have a oil they recommend when they rebuilt the one i had. they arent cheap if they go bad....lol
