Oil line help??
blazinsrt
Philly, PA
So did some searching and came up blank. What size wrench are the factory lines? I have new JTSV oil lines I was getting ready to swap out and happened to find out I didnt have the right size wrench. Can you get in there to change them with a regular wrench looks tight? I need to get this done before my carlise trip. The factory lines are pretty wet.
man, i keep comin up with an 1 1/6" socket to get the factory fittins out of the block.
if it will help, i can check for ya tomorrow
I believe I used crowfeet, but I can't remember the sizes.
1 1/16 ...1/2 SOCKET
with a small pocket screwdriver, remove the clips an the lines come out of the quick disconnects from there a socket will fit over them
Awesome thanks. I am guessing you mean pulling back the black circle plastic where the line goes into the fitting?
Thanks for help. I got my new oil lines installed today!!! I can't believe those factory lines where built that way... What junk.
