supercar1of1
Item# 306-6001
$49.95
Product Description
Razors Edge's oil separator kit reduces detonation, oil burning and deposits on the valves by removing oil drawn through the PCV system before it can contaminate the intake charge.
Excess crankcase pressure (sometimes known as "blow-by") is vented from the crankcase through the PCV system, where it is drawn into the intake manifold and returned by the engine. This re circulated air contains aerated oil from the crankcase which is burned by the engine. Supercharged, nitrous boosted and high mileage engines often draw excessive amounts of oil into the engine through the PCV system. The Razors Edge oil separator plugs into the PCV hose between the PCV valve and the intake manifold and removes aerated oil from the re circulated air and collects it in a tube that can be drained and recycled.
Kit come complete with all lines and Brass fittings,
Not plastic like some other imitators.:rock:
http://www.razorsedgemotorsports.com/raedoilsekit.html
$49.95
Product Description
