Oil temp gauge busted
Soapy00
Marcus Hook, PA
I think this was an add-on by the previous owner, but it's the handle bar panel that has the oil temp pod gauge...it's just stuck and not moving. Is this cooked or can I fix it somehow?
Sent from my Nexus 6 using Tapatalk
Its not an add on its a factory item that fails sometimes. Your only choice is to replace it.
Replacement is the only way.
I carry brand new OEM ones boss and sell them often. They'll usually stick around 140-160 when wngine is off. That's telltale sign it's out boss
Venomous, do you also sell the middle back window clip? That broke the same day. Haha
Man honestly you'll likely be better going to a glass place on that. It comes as an assembly :(
