Ok new clutch and such.....
RAMDUDE
DOGFATHER
Maryland
Ok so new clutch , flywheel and whole slave upgrade.
Clutch petal feels so much easier to push in now compared to when i bought the truck, is this normal for that upgrade kit.
factory clutch and flywheel were tore up pretty bad, about a papers worth of clutch surface left very very bad.
I think who ever owned this truck before me did not know how to drive a stick.
Also before when you would wrench through the gears when going from gear to gear pushing the clutch in, the rpm's would not go down very fast.
Now when going from gear to gear when clutch is pushed in the rpm's drop very fast, would this be normal also?
If you put in a lighter flywheel that will allow the revs to climb and drop faster. So, yep, very normal.
