This one is easy. a planes wings create lift moving through air. Less air, less dense air, IE altitude. Thats why you don't find prop air planes flying around at 50000 feet. Nor do you find jets 5000 miles in space. Still trying to figure out what wheel speed over a conveyor belt had to do with a plane lifting off. We tie light air craft to the ground so they don't lift off in a 60 mile an hour wind without a pilot aboard. If it does not move through the air? No lift. And for the wise guys. I know all about a Harrier jet. If you stood a prop plane on its tail with enough thrust it would go up. For how long? Its called hanging from the prop in aerobatics.
A jet plane is traveling at 2800 feet per second over the ground heading north. You fire an M14 308 bullet that travels along at 2800 feet per second over the ground heading south? Whats gonna happen to the bullet. The bullet will fall out of the barrel because it is moving at the same speed as the jet? If you believe this? Would you stand in front of that M14. I don't think so! Think of it this way. If you were on a US space craft speeding along at 2000 + mph away from earth. Thats faster then a speeding bullet. Point the M14 to wards earth and pull the trigger. A little rocket ship will come out the end. Please do not try this, will cause harm or death. A bullet carries its own potential energy regardless of the speed or direction it is going away from or heading to wards. Speed as we calculate it is only relative to earth, which spins and travels through space at a tremendous speed. Who really knows? Ask the Prof.
How far can you go into the forest? I like center, rather then half way. Forests are normally not on a flat surface. They are up and down. The center is the center even if you get caught inside a mountain before you can start heading out. I know this is splitting hairs but center is center. Half way between heaven and earth and I just am not sure where the hell I am at. AKA the rambler
