kickinassrt-10
I found out the output shaft sensor is in the rear tail driver side area of the transmission. I guess it's the over drive area.
I took a picture and it may well be the smaller problem right now because it is covered in trans fluid. The pan also has fluid on it. There is still another problem but hopefully this part can hold the trans over for a few weeks.
The right side of picture is toward the ground
