Paxton help
34bud
Colbert Wa
Just fired her up all seems well going to dyno next week before I drive it. trying to figure out how the compressor bypass works at a idle the plate is open as to bypass when I wick the throttle to 4-k it closes but not completly not sure if its working properly. Also I taped into the vac to the Paxton ecm for boost gauge but Im not showing any boost on the gauge. DC perf. told me to tap into it there. Could it be because the engine is not under load.
just as Santeen said; won't develop any boost until under a load, gauge should be showing a vacuum, though, depending on gauge l guess, and should go up to close to zero just blipping the throttle, but won't or shouldn't make any boost 'til under a load...
l'm not exactly sure offhand where my gauge tap is, but l know my blowoff is blowing air at idle, and less when hitting the throttle, but l don't think it fully closes until under a true load.
