DevilDawg3097 said:
YUP
:marchmellow: :smokin: :canabis: :turtle: and then off to bed
Have a safe trip brother and give eddies kid a kiss and hug and tell him OOHRAH MARINE:rock:
will do sir:rock:
finisher most builders are gonnna be around the same price, or at least close.
but if you want a bullet proof bottom end, there are a few things to know.
one, what compression you want to run, are you gonna use NOS?
but rods, k1 makes a good rod good for 1200hp, around $800
oliver makes killer rods, good for 1500hp+ $1800
pistons, all in the buyers choice, i reccomend wiseco or je
billet mains, if you want a strong bottom end go with mains, they are more 4 but the oem mains tend to walk, and can cause problems
mains in the area of $750-$800, and machine work about the same.
and go with a good hardened set of rod and main bearins, preferably coated.
now on to the paxton,
with the paxton i think you will get best results without doing any headwork, maybe valves, springs pushrods, but leave the chambers alone.
and run oem manifolds, if you want headers, run a hi flow cat.
now on the cam, a custom cam is your best choice, one with alot of overlap, that will help the truck build more boost.
then jsut get one of the venom edition lower pullies so no more paxton slip and havee a ballllll
