Paxton Supercharger
Discussion in 'SRT-10 Trucks and Parts For Sale' started by LitemUp, Sep 16, 2017.
  1. LitemUp
    LitemUp Active Member Supporting Member
    2,262
    6
    May 22, 2006
    The Looney Bin
    Ok, guys I haven't posted much in the last few years. I'm thinking about pulling the supercharger of the truck and selling it. This is a feeler thread to see if someone will be interested. So here is the breakdown.
    1. Paxton Supercharger kit polished it has a custom bracket setup to run direct from the crank on it own 8 rib belt similar the Procharger. Doesn't piggy back off the accessory belt. That I know of there are only 3 setups like this. I have on it now a 2.8" pulley producing 10-12 lbs of boost. You can you smaller and get upto 15 psi with a 2.75" pulley if you desire.
    2. I have upgraded the following: heat exchanger, bigger pump for the water to air intercooler, intake pipes (no cheapy drier hose), will come with bigger injectors 60lbs, custom crank pulley (you will need to key your crank), OEM fuel pump assembly with Roe Racing fuel pump 400 lph (will support upto 820 rwhp STILL BRAND NEW), Votech Race bypass valve, and Snow performance stage 3 kit.
    3. You will need an SCT Tuner and a tune after its been installed.
    Asking $5k let me know if anyone is interest email: [email protected] I'm sure you can go to my previous threads and see most of the pics of the system.
  2. IronAffliction
    IronAffliction Full Access Member
    563
    Apr 27, 2015
    yelm WA
    Why are you selling?
  3. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    I want to go turbo.
  4. IronAffliction
    563
    Apr 27, 2015
    yelm WA
    Nice choice. Wish i could buy it man. glws
  5. viperhauler
    18,950
    44
    Jul 27, 2008
    want to sell the belt drive?
  6. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    Nah, just want to sell the entire kit completely.
  7. NVR2OLD
    NVR2OLD VTCoA Senior Member
    1,190
    2
    May 11, 2010
    Rapid City, South Dakota
    Could you post some pic's of the supercharger?
  8. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    Decided to keep it. No longer for sale
  9. Kx1984
    Kx1984 Full Access Member
    28
    May 27, 2017
    New York
    was about to ask for pictures
    let us know if you change your mind
    Ive been on the fence
    Kx
  10. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    Now, that is all put back together and went with the smaller pulley I’m not going to be selling it anytime soon.
  11. Kx1984
    28
    May 27, 2017
    New York
    Thats fine still on the fence :D
    Kx
  12. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    I had a few of you requesting pics of what the dedicated belt drive setup looks like, so here are a couple of pics.
  13. tomdragoo
    tomdragoo Full Access Member
    33
    Dec 28, 2017
    Sent from my iPhone using Tapatalk
  14. tomdragoo
    33
    Dec 28, 2017
    I have the same set up on my 2006 srt 10 ! But I think there is parts missing, like for example the plate that hold the entercooler . Can you take more pics of the hole system?! Just trying to find out what’s missing plus make it better safe and less worry about breaking something! I have only owned the the sentence the first of this dec 2017 and already needing work done ! Thanks
  15. Pirana131313
    Pirana131313 Full Access Member
    544
    May 11, 2012
    Who did the work for the dedicated drive?
  16. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    Doug Levin, but he is not making them anymore.
  17. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    Ok, just to give you an update. Since changing the blower pulley to 2.75 I've had some issues snapping the idler pulley bolt that is located next to the stock tensioner pulley. So the issue is that with the smaller puller I'm getting belt flap on the back side of the blower pulley and the vibration of the belt is causing the bolt to snap on the idler pulley. So to correct the issue I'm placing an additional idler puller just below the tensioner puller on the blower to keep the belt from flapping. (see pic)
    I order the pulley just my luck no one here locally has one. Ordered it on Friday last week so I should have it in by end of week. I've also having some spacers made for the new pulley to bolt up the blower and brackets, and will be getting them today. If all goes well should have the truck up and running by Saturday afternoon.
    I'll take some more pics with the new pulley installed, and post them when done.
  18. LitemUp
    2,262
    6
    May 22, 2006
    The Looney Bin
    Ok, the bracket that I have on there is the once that come with the kit from Paxton "Charge Air Support Bracket" I couldn't find the part number for it. It's supposed to bolt the heat shield on the stock mainfold, but since I have headers I needed to modify it. I have attached pics sorry I don't have better ones.
  19. tomdragoo
    33
    Dec 28, 2017
    I built my own still having problems with the serpentine belt belt drive I need a bullet proof through everything out it system. How are you when your project come along. Seems like I have embarked on myself
  20. tomdragoo
    33
    Dec 28, 2017
    I have plenty a picture of the supercharger. It’s all new to me! But I’m still trying to ride that bike
