Finaly got the new exhaust gasket which fixed my problem, but I still have another problem I need to iron out before I hit the spray. I'm still running lean, even at idle the A/F is between 15-16.5. When I'm crusing it does'nt change much until I let off the gas and then it runs in the high 16's to even maxing out the gauge wich goes to 18. When I drop the hammer, it stays in the mid to low 13's.
Oh yeah, when I changed out my spark plugs there were definate signs of detination. Is this lean thing caused by the Stage 2 flash? Also can I have them reflash the PCM to retard the timing 1-2 degrees for the N2O?
