PLX Dm6 Wideband combo
Kopack_05
Florida
Anybody running one of these O2 wideband gauges. It looks like you can add modules to one gauge and monitor left and right bank widebands as well as other sensors. It says you can add these widebands in place of your narrow bands and send the narrow band signal to your ecu from the module. ???? or would you just add the extra O2 bungs??
Is it a solid product? I probably will just add the O2 bungs instead of the narrow band outputs. I've seen a few bad reviews about the dm6 touchscreen being glitchy. I'm thinking of adding this in the pillar pod and replace the oil temp gauge and just add the correct sensor for the dm6 to pick up the oil temp. Do you know if the stock oil temp sending unit is connected directly to the gauge or routed through the ecu?
I have had no problems with mine, been installed for 2 yrs. no idea on oil temp.
