LORD CHAVEZ
Yup I can get you a deal on stock or aftermarket sir.
Can install it too if ya can get it to me. Jason at TDP is fairly close to you as well and he's good people.
I need to find out wat exactly it is first
I have seen this a few times. What gear did you miss? The clutch over reved and came apart, I did this at the track when I miss third and went back to first. Even though I didnt let the clutch out. Same thing happen to a friends only he put his in first as he rolled of the freeway at 65mph. It spinns the input shaft up to 10k rpm the clutch is only good for about 7500.
new clutch and flywheel will set you back about 500$ labor should be cheap 2-3 hour job unless stuff is really fubared.
I was in 6th goin 70 and i would try to step on it and it wld just rev up and then it just reved up and popped and that was it.
You just wore your clutch out then, if it was slipping and you kept reving it it built heat till it explodifyied.
Yea prolly just sucks cuz im fairly new to area and have no shop or tools or friends to help out.
There is nothing special about changing our clutchs, you should be able to find someone cheap. If you were closer I would just tell you to bring it by and we could do it on my lift.I have done it some many times its not even funny.
A clutch exploding is rare but not a huge problem, and easy enough to fix. You did get lucky I have seen the do some major damage, and I beleave a forum member here had his explode and it totaled the truck.
no help from Dodge???
Been at work since noon and dnt have my vin with me
dam pesky work, lol:marchmellow:
You can tell when clutch disc is worn when you try to give it gas on the highway in 6th and it slipsMan I hate this for you. I hope you can find a fairly inexpensive clutch and install. This concerns me with 74k and many track passes on my stocker. Would you say there were any signs recently now looking back?
You can't drive like a maniac and expect it to last.
LmfaoMaybe Kwik Lube can fix it.
any news/updates????
